RUT241 in passthrough mode for backup internet connection (high packet loss)
Hello, I encountered an issue back about two years ago with heavy packet loss when trying to use a RUT240 as a backup internet connection for Ubiquiti UniFi routers, and specifically when the connection is not active but only being periodically checked for connectivity. I started a convo about it but never went anywhere as I didn’t hear from tech support outside of the forum…
Random Packet Loss with RUT240 in Passthrough Mode - NETWORKING SOLUTIONS - Teltonika Community
Anywho, two years later and I’m re-testing this application with a RUT241 running the latest firmware and encountering the same issue again. Any assistance would be greatly appreciated. Thank you
Thank you for reaching out. In this case, to assist you effectively, we’ll need to continue this process privately, because sensitive/publicly unshareable information needs to be gathered. You should find a support request form in the inbox of the email address you used for your forum registration. Kindly fill out the form, and please reference Ticket ID: 14568 when submitting it. Once the form is completed, we’ll contact you directly via email to investigate the issue in detail and help work towards a solution.
Thank you very much for the quick reply! I’ll follow-up with you via email.
