please, our RUT241 industrial 4G eSIM™ router is unable to connect to the internet via WAN. It connects with a physical SIM, but to insert an eSIM, WAN is required. I could not find a connect via Wifi function.
I connected RUT241 (192.168.1.1 / RUT2M_R_00.07.11.2) via Ethernet cable (in good condition, WAN slot) to the router (TPLink, 192.168.1.10, LAN slot). The router assigns an IP using DHCP and recognises the connected device. RUT241 receives its IP, but is still not connected to the Internet. Other devices connected to the router via DHCP are accessing the Internet.
On RUT241, I have deactivated
- all restrictive firewall rules
- SIM and eSIM auto APN (advice found on the internet)
to no avail.
By CLI, RUT241 does not ping its router 192.168.1.10.
root@RUT241:~# ping 192.168.1.10
PING 192.168.1.10 (192.168.1.10): 56 data bytes
^C
--- 192.168.1.10 ping statistics ---
9 packets transmitted, 0 packets received, 100% packet loss
No CLI on TPLink, but on the same network, no response to another PC’s 192.168.1.1 ping.
Could you help us?
Thanks in advance!
fmg
tplink:
RUT241:
firmware:
