Hello
Please
I’m following up on this ticket (https://community.teltonika.lt/t/rut241-can-not-add-an-esim-download-failed). After our private exchange (26113579.eu1.r.hubspot-inbox.com) and my two reminders by email, I have had no news. This is eSIM Free in France. Could you please help us? Because without it we can’t use your product.
Thank you in advance
fmg
FW version? Also, router has WAN connection?
Could you please confirm if your device has a direct connection to the internet? This solution has helped resolve the issue for another user.
Additionally, I have checked HubSpot, and unfortunately, we have not received any emails from you.
thank you for your reply.
Latest version of FW, WAN connection active. I’ve sent you a troubleshoot file that I can e-mail back to you, if you give me an address.
Here’s our exchange:
Please,
Did you receive my last message?
Without your help, we cannot use your product.
Thank you in advance!
Fr. M. Georges
De : Frère Georges
Envoyé : vendredi 3 janvier 2025 15:28
À : support@26113579.eu1.r.hubspot-inbox.com
Cc :
Objet : RE: Regarding RUT241 eSIM issueHello,
please, did you find where our problem comes from? We can propose you to make a VPN to take the hand on our device RUT241 eSIM.
Thank you for your answer, otherwise we can not use your product.
Sincerely
Fr. M. Georges
De :
Envoyé : lundi 16 décembre 2024 09:12
Cc :
thank you for your message.
here’s the log attached.
nice day
Fr. M. Georges
De : Networks Support <support@26113579.eu1.r.hubspot-inbox.com>
Envoyé : lundi 16 décembre 2024 09:08
À :
Objet : Regarding RUT241 eSIM issueHello,
Thank you for reaching out.
To troubleshoot your issue more precisely, could you please download and attach a troubleshoot file by replying to this email? The troubleshoot file can be generated and downloaded in the router’s WebUI by navigating to System → Maintenance → Troubleshoot.
We look forward to your response so that we may assist you further.
Thank you very much!
fmg
Thank you for sharing the information. Strangely, it still shows an empty chat on my side. If possible, could you please provide the ticket ID you used when filling out the form? I will reach out to the person you had a conversation with.
We apologize for any inconvenience caused.
here is the message found on 13/12/2024:
Please complete the form and use “11041-1” for the ticket ID.
thank you
fmg
We apologize for any inconvenience, but we haven’t received any of your emails on our end. I’ve sent you the form again—could you kindly fill it out using a different email address this time? Please use “11784” as the ticket ID.
I have just sent the form.
thank you
the log file has just been e-mailed
I suggest you set up a VPN to take control of the device, as we had already spent a lot of time on it
thanks in advance for your feedback
Thank you for providing the troubleshoot package. I will forward it to our RnD team for further analysis. Once I receive any feedback from them, I will update you promptly.
We appreciate your patience and understanding.
Please, do you have anything new?
We’re a bit desperate…
fmg
I just wanted to confirm that you should have received an email from us. Could you kindly check and let us know if it has arrived?
If not, please let me know so we can resend it or assist further.
Thank you for your message. Yes, I received the email from your support team. Here is my answer:
We’ve tried it countless times. I imagine that you have traces of it in the log sent.
First by scanning the QR code.
Scan result:
LPA:1$frm.prod.ondemandconnectivity.com$P8YD…GW$$1
downloading was immediately impossible.
Then we tried multiple combinations, copied the code given in text format by Free France… always without result.
Finally, following the advice found on internet, we omitted the last two symbols. Result:
LPA:1$frm.prod.ondemandconnectivity.com$P…GW$
Then only the download began, but still failed. Can you see the details of these deadlines?
We had not been able to proceed to the next step, which was to receive the verification code.
Can you help?
Thank you for your help!
fmg
PLEASE
were you able to find any solutions?
fmg
The developers are currently analyzing your issue, and at this moment, there are no solutions. Once I receive a response from them, I will let you know.
We appreciate your understanding and patience.
I have the exact same problem with the same carrier (free, in France). Have you been able to find a workaround ?
Thank you
This issue is expected to be resolved with the upcoming 7.14 RutOS firmware. Unfortunately, I don’t have an exact release date yet, but I will update you as soon as I have any news.
The firmware update you provided us with enabled us to install several free.fr eSIMs successfully, thank you very much!
However, we’re encountering many other problems. Here are the main ones:
- the connection cuts out very often. It’s impossible to hold a videoconference, for example.
- Switching from one eSIM to another when the programmed limit is reached is frequently problematic.
- Even if the limit is not reached, sometimes it’s the physical SIM that’s called upon, even though it’s in 5th and last position and there are other eSIMs before it.
- At start-up, the limit of the 1st eSIM was mistakenly misconfigured (too high), and when the data was exhausted and the connection cut off by Free, there was no more Internet, because the router didn’t switch to the next eSIM.
- On the router’s web interface, the wifi scan didn’t work (an error message)
- the router’s wifi doesn’t work continuously, so connected devices often lose connection
I don’t know whether these initial problems were caused by the router or by the Free operator… The physical SIMs were working correctly in another router.
I can provide you with the troubleshoot logs again.
Thank you in advance for your reply.
fmg
The test firmware was provided specifically to address the issue of installing the eSIM profile and is not intended to use widely or in production. We kindly ask for your patience while we work towards the official release of the 7.14 firmware, which should resolve the issues you are experiencing.
Thank you for your reply. Could you let us know as soon as the official firmware is released? Thank you and have a nice day
