RUT240: Unable to update firmware, getting error "The uploaded image file does not contain a supported format."
I have tried to update the firmware on my RUT240 by downloading the latest FW (RUT2_R_00.07.06.13_WEBUI.bin) from https://wiki.teltonika-networks.com/view/RUT240_Firmware_Downloads, then going to the Web UI, navigating to System / Firmware, selecting “Upgrade from file”, “Choose file”, selecting the downloaded FW file (RUT2_R_00.07.06.13_WEBUI) and pressing Upgrade.
This leads to the following error message being shown: “The uploaded image file does not contain a supported format.”
What might be going wrong here and what can be done about it? Thanks!
Hello. Please, check this thread: RUT240, Can't fw-upgrade to version 7.6.13
@hrtx is correct. Please check the provided thread for instructions on how to install updates if they are not recognized.
It sounds like you might be encountering a file format issue. Make sure the firmware file you downloaded is not corrupted and that you’re selecting the correct file type for your RUT240. Sometimes, renaming the file or ensuring it’s fully downloaded can help. If the problem persists, try downloading the firmware again from a different browser or check if there’s an updated version available on the Teltonika website.
