RUT240, Can't fw-upgrade to version 7.6.13
with a RUT240 I have problems to do a firmware upgrade from remote.
The device had the version 7.05.4 installed. I tried to upgrade by WEB-UI to 7.6.13 “from server” and “file”. Both uploads were checked as OK. But after “proceed” the old version is still active.
Then I did a “file-Upload” of version 7.6.3 as a intermediate step. This was installed successfully.
But, again, I’m not able to upgrade to 7.6.13 “from server” or “file”, now from 7.6.3.
Here a output of hexdump -C /dev/mtd1
root@Teltonika-RUT240:~# hexdump -C /dev/mtd1
00000000 00 1e 42 44 32 24 ff ff ff ff ff ff ff ff ff ff |…BD2$…|
00000010 52 55 54 32 34 30 30 36 58 58 58 58 ff ff ff ff |RUT24006XXXX…|
00000020 30 31 32 33 34 35 36 37 ff ff ff ff ff ff ff ff |01234567…|
00000030 31 31 31 38 37 31 33 36 35 35 ff ff ff ff ff ff |1118713655…|
00000040 30 31 30 33 ff ff ff ff ff ff ff ff ff ff ff ff |0103…|
00000050 30 30 31 30 ff ff ff ff ff ff ff ff ff ff ff ff |0010…|
00000060 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |…|
00000080 37 32 32 34 34 37 30 38 ff ff ff ff ff ff ff ff |72244708…|
00000090 70 30 53 34 42 67 6d 38 ff ff ff ff ff ff ff ff |p0S4Bgm8…|
000000a0 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |…|
00010000
root@Teltonika-RUT240:~#´´
I have a troubleshooting-download available.
Any idea want is going on, and a hint to solve this from “remote”?
Solarix
Some RUT240 and other EOL devices may encounter this issue. One known way to resolve it is to run the attached script below, either from the WebUI or CLI:
chmod +x wdt.sh && ./wdt.sh &
wdt.zip (383 Bytes)
Thank you again…
A upgrade to 7.6.13 was now successfull.
The script showns these output:
“status”: “offline”,
“timeout”: 21,
“frequency”: 5,
“magicclose”: true
“timeout”: 21,
“frequency”: 5,
“magicclose”: true
and did what?
Do I have to be aware, that I need the script for that device in the future again?
Thanks and nice Weekend
Solarix
I’m glad the script worked! In the future, you can try upgrading without it. However, keep in mind that the RUT240 is an End-of-Life (EOL) device with limited memory, which can make firmware upgrades difficult. If you encounter problems with upgrading again, feel free to use the same script.
