Routing between Wireguard and IPsec
I have Teltonika RUTX10 with firmware 7.14.
I have a Wireguard setup for road warriors and a site-to-site VPN setup to an Azure network.
Both work and I can ping the local LAN from both however, the Wireguard user cannot reach the IPsec network. Is there additional routing/firewall settings I’m missing?
Thanks in advance,
Ben W
To better assist and understand the setup, could you please provide a topology (including IP addresses/subnets) of how your setup looks and/or how it should work?
Also, just to note, the 7.14 firmware version was removed due to some issues affecting mobile functions, so it’s strongly recommended to update to 7.14.2 following the instructions provided here.
Additionally:
  • Could you confirm if the Azure network (IPsec subnet) is added to the WireGuard client’s Allowed IPs list on the RUTX10?
  • On the IPsec network configuration, the Remote Subnet should also include the WireGuard client’s subnet to allow traffic to route correctly between both VPN tunnels.
