RMS VPN Hub at TAP mode?
I have some Siemens DXR2 controllers that, as far as I know, need to be on the same network as the programming software. I think the only way to work would be to declare the VPN as Layer 2 (TAP Mode), but the RMS doesn’t have that functionality… Is it planned to be available soon? Where can I check it? Thanks.
Currently, we don’t have any definite information about when Layer 2 VPN will be available on RMS.
Marijus
Thanks for the reply. But is it proposed that it can be supported, even if it is undated?
Yes, it can be supported and in the future most likely will be.
Marijus
