hi ,
i wrote a code that if i want simplify it : it’s a program(python) that can get imei and server port then connect to server (via socket programming ) and send DATA PACKET to server USING TELTONIKA PROTOCOL (for example sending lat, lon , angle ,speed, etc) over TCP/IP but the problem is i can get the correct response from teltonika server (x01 or 01 ) BUT the destination server(traccar.org) cant get the SECOND PACKET (the data after imei check in TCP ) correctly(it doesnt show any lat , lon )
HERE ARE THE CODS AND OUTPUT (below links)
Custom applications are outside the scope of our technical assistance. However, if you are looking to use your Teltonika router with traccar, it is already possible without additional applications.
