As previously notified for FW 00.07.09 RUTX50 - FW07.09 NTRIP Enable failing continues to have the same issue with FW 07.10
I was unable to replicate the issue with the 7.10 firmware version. Could you please provide the steps to replicate it, along with any relevant screenshots?
Yes as per 7.10 screenshot which is essentially the same as what occured when going from 7.8 (which was working ok) to 7.9 when this issue was first noticed.
On the Services>NTRIP NTRIP configuration, Enabling any instance (toggle On/blue Save & Enable) flags the issue as appears in red. Note Instance is Down even though toggle shows blue/On. This is also confirmed in CLI using cat /etc/config/rs_ntrip as Enabled “0”
Coming back to Services>Ntrip toggle is OFF
Instance can be turned on via Services>NTRIP> NTRIP configuration Edit (any configured instance) and Enable on NTRIP instance configuration tab Save&Apply provides the Green tick Configuration has been applied and Instance shows as UP
A proper/valid Enabled instance can be turned OFF from the Services>NTRIP NTRIP configuration page but cannot be Enabled
RUT956 also shows the same issue.
Thank you for all the information. I have sent you a form to fill out. Once completed, I kindly ask you to send the troubleshoot file so that I can forward it to our RnD team. For the ticket ID, please use “9744”.
