No 5G connection on TRB500
I am trying to connect to 5G with the TRB500, but the device is just connecting to 4G.
I updated the firmware version from the server to TRB500_R_00.07.12
I updated the internal modem firmware to RG501QEUAAR12A11M4G_04.200.00.000 like described in TRB500 modem update proceedure
Here are some outputs:
root@TRB500:~# gsmctl -A ‘AT+QENG=“SERVINGCELL”’
+QENG: “servingcell”,“NOCONN”,“LTE”,“FDD”,262,02,XXXXXX,330,100,1,5,5,B15A,-116,-9,-86,13,0,-,8
root@TRB500:~# gsmctl -A ‘AT+QCAINFO’
+QCAINFO: “PCC”,100,100,“LTE BAND 1”,5,330,-114,-9,-85,7
best regards,
From the output, it appears that the signal strength is very poor, which is likely the cause of the issue you are experiencing. When the signal strength drops below -100 dBm, a stable and reliable mobile connection cannot be guaranteed.
Please ensure that the original mobile antennas are properly connected to the RUTX50 at a 90-degree angle. Additionally, you may want to consider using a higher-gain antenna. If the device is stationary and the location of the cell tower is known, a directional antenna could be a good option. This type of antenna provides the best signal but must be properly aligned with the cell tower for optimal performance.
Once the signal improves, I recommend replicating the issue to see if the situation changes.
Additionally, please check the following:
  1. PDP Type: Navigate to Network → WAN → Mobile Interface → Edit and ensure the correct PDP type is selected.
  2. APN Settings: Verify that the correct APN is being used, and try setting it manually if necessary.
