I created a short video showing the LEDs while the speed test is running and the router loses connection to the provider.
From your attached video, it seems like the internal LTE/5G modem restarts during the test you’re running. I can’t access the logread logs, but I presume it contains messages about a disconnected USB device.
If that’s the case, please ensure that:
- You’re running the latest modem firmware - please navigate to System → Firmware, and check if the internal modem is on the latest available firmware. Please also attach the version you currently have installed to your next comment.
- Try disabling the IMS service - leave VoLTE set to OFF, and then via the CLI, run the following command:
gsmctl -A 'AT+QCFG="ims",2'
Then re-run your test
- Make sure all 4 antennas are tight and on the correct ports.
Firmware: RG501QEUAAR12A11M4G_04.200.04.200
It was unsuccessful. I conducted two tests after disabling IMS. After the first test, it took about 2 minutes for the system to fully reboot. During the second test, the system was back online after about 1 minute.
Here the log-read
Thank you for the logs - and regarding the internal modem firmware - could you clarify what version is currently installed?
Since you already have almost the latest modem firmware version, I believe we should try to replicate the logs during a remote session for our RnD team.
If a remote session could be organized, then please fill out the form I’ve sent to your email address and we will arrange remote session details privately.
Thanks!
Do you have a ticket ID?
Sorry, it’s 10755.
Hi Team,
can anyone provide command for Cell lock in 5G. i am not getting any command for that.
Hello @rahul ,
Please refer to this topic: TRB500 Lock to Cell Problems.
If you still have any questions not related to the issue with N78 band, kindly create a separate topic. Thank you.
