Iphone14 connect through USB RUTX50
As an alternative I’d like to use my phone as WAN. When I connect through cable I cannot find my phone in order to choose it as WAN.
Best regards
/Anders
USB tethering is not supported on the RUTX50, so it’s not possible to provide internet access to the device via the USB port. However, you can share a hotspot from your phone and connect the RUTX50 to it using WiFi by configuring WiFi as WAN.
You can follow this configuration example for detailed steps: WiFi WAN example - Teltonika Networks Wiki
The problem with this is that when I remove the phone it will not automatically connect as a Wan-source when back to the router. I have to remove the phone, scan 2,4GHz and connect again.
I have answered on the other topic you created (Iphone as Hotspot RUTX50). We can continue the discussion there.
