I’m trying to create Grafana dashboard with some basic informations about data usage and gsm modems status. To get the data, I’m using RUT955 REST API, specifically Teltonika Networks Web API endpoint. The issue is, there are random drops in reported data usage values which make no sense to me. Did I missed some documentation, which explanis it? Is it normal? I tryied to clear internal db using “ubus call mdcollect clean_db”, which helped for a day or so, but now it’s back. Drops are “small”, right now, up to 10MB, but occures multiple times per day at random times.
Here you can see drops in reported data usage:
RUT955 - FW: RUT9_R_00.07.06.13
Thank you
