How fetch router (RUTX10) uptime data by API or etc
Hi everyone,
I’m using RUTX10, and I’m going to use router log-like uptime in third-party applications. How can I access them through API, etc.?
One way is to use snmp, it will give you the router’s uptime :
[root@fdf ~]# snmpget -v 2c -c public 192.168.98.1 1.3.6.1.2.1.1.3.0
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (8882623) 1 day, 0:40:26.23
or
[root@fdf ~]# snmpget -v 2c -c public 192.168.98.1  iso.org.dod.internet.mgmt.mib-2.system.sysUpTime.0
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (8909710) 1 day, 0:44:57.10
You can also use RUTOS API: https://developers.teltonika-networks.com/
The particular endpoint that contains router’s uptime as one of its data points is: /system/device/usage/status
When executed directly on the router’s CLI with some filtering applied:
  • api GET /system/device/usage/status | jsonfilter -e ‘@.http_body.data.uptime’
The command above returns:
