I cannot find it in package manager; could someone let me know what is the correct way to do this ?
Look at this topic and follow the reference you’ll have a working recipe.
@flebourse thanks for the link I installed with opkg but going to 192.168.1.1:3000 gets me a blank page. The thread is locked so I cannot post there; can you help ? no sure how to troubleshoot this
root@RUTC50:~# /etc/init.d/adguardhome status
running
cat /etc/init.d/adguardhome
#!/bin/sh /etc/rc.common
PROG=/usr/bin/AdGuardHome
USE_PROCD=1
# starts just after network starts to avoid some network race conditions
START=25
# stops before networking stops
STOP=89
start_service() {
config_load adguardhome
config_get WORK_DIR config workdir
[ -d "$WORK_DIR" ] || mkdir -m 0755 -p "$WORK_DIR"
/bin/mkdir -p /tmp/var/adguardhome/data /opt/var/adguardhome/data/filters >/dev/null 2>&1
/bin/ln -sf /opt/var/adguardhome/data/filters /tmp/var/adguardhome/data >/dev/null 2>&1
procd_open_instance
procd_set_param command "$PROG" -c /etc/adguardhome.yaml -w "$WORK_DIR" --no-check-update
procd_set_param stdout 1
procd_set_param stderr 1
procd_close_instance
First step: check if adguardhome listens on port 3000. For that install lsof using the same distfeeds.conf method then execute
lsof -n -P -p $(pidof AdGuardHome)
You should have one file descriptor indicating a LISTEN state on port 3000.
Second step: check that TCP SYN packets are received by the RUTX:
tcpdump -i any -n -v 'port 3000'
and send a request for 192.168.1.1:3000. Do you see something in the tcpdump output ?
From what I can see the process is not listed with lsof; I used 1 from the init file but I am not sure if that is correct. So I also run lsof -n -P and made a search on the console output for adguard and could not find anything.
tcpdump receives on port 3000; btw I changed my lan to 192.168.0.x/24
weird because service adguardhome status says it is running
root@RUTC50:~# lsof -n -P -p 1
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
procd 1 root cwd DIR 254,0 281 5442 /
procd 1 root rtd DIR 254,0 281 5442 /
procd 1 root txt REG 254,0 101681 1516 /sbin/procd
procd 1 root mem REG 0,21 27 189 /tmp/TZ
procd 1 root mem REG 254,0 73744 1097 /lib/libgcc_s.so.1
procd 1 root mem REG 254,0 12305 1098 /lib/libjson_script.so.20240329
procd 1 root mem REG 254,0 12291 1094 /lib/libblobmsg_json.so.20240329
procd 1 root mem REG 254,0 65574 1799 /usr/lib/libjson-c.so.5.1.0
procd 1 root mem REG 254,0 24714 1101 /lib/libubus.so.20210630
procd 1 root mem REG 254,0 69729 1100 /lib/libubox.so.20240329
procd 1 root mem REG 254,0 545793 1095 /lib/libc.so
procd 1 root 0r CHR 5,1 0t0 50 /dev/console
procd 1 root 1w CHR 5,1 0t0 50 /dev/console
procd 1 root 2w CHR 5,1 0t0 50 /dev/console
procd 1 root 3w CHR 10,130 0t0 26 /watchdog
procd 1 root 4u a_inode 0,9 0 1028 [eventpoll:5,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,25,26,27,29,30,32,34]
procd 1 root 5r FIFO 0,8 0t0 3717 pipe
procd 1 root 6w FIFO 0,8 0t0 3717 pipe
procd 1 root 7u netlink 0t0 3718 KOBJECT_UEVENT
procd 1 root 8u unix 0x0000000060df3148 0t0 310 type=STREAM
procd 1 root 9r a_inode 0,9 0 1028 inotify
procd 1 root 10r FIFO 0,8 0t0 122812 pipe
procd 1 root 11r FIFO 0,8 0t0 5787 pipe
procd 1 root 12r FIFO 0,8 0t0 7269 pipe
procd 1 root 13r FIFO 0,8 0t0 6335 pipe
procd 1 root 14r FIFO 0,8 0t0 7330 pipe
procd 1 root 15r FIFO 0,8 0t0 6336 pipe
procd 1 root 16r FIFO 0,8 0t0 7409 pipe
procd 1 root 17r FIFO 0,8 0t0 6482 pipe
procd 1 root 18r FIFO 0,8 0t0 6573 pipe
procd 1 root 19r FIFO 0,8 0t0 6654 pipe
procd 1 root 20r FIFO 0,8 0t0 154217 pipe
procd 1 root 21r FIFO 0,8 0t0 6655 pipe
procd 1 root 22r FIFO 0,8 0t0 7822 pipe
procd 1 root 23r FIFO 0,8 0t0 9838 pipe
procd 1 root 25r FIFO 0,8 0t0 10357 pipe
procd 1 root 26r FIFO 0,8 0t0 9839 pipe
procd 1 root 27r FIFO 0,8 0t0 154218 pipe
procd 1 root 28r FIFO 0,8 0t0 10402 pipe
procd 1 root 29r FIFO 0,8 0t0 10766 pipe
procd 1 root 30r FIFO 0,8 0t0 10403 pipe
procd 1 root 32r FIFO 0,8 0t0 11132 pipe
procd 1 root 34r FIFO 0,8 0t0 11133 pipe
root@RUTC50:~# tcpdump -i any -n -v 'port 3000'
tcpdump: data link type LINUX_SLL2
tcpdump: listening on any, link-type LINUX_SLL2 (Linux cooked v2), snapshot length 262144 bytes
08:51:04.182534 lan1 In IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 64)
192.168.0.199.60315 > 192.168.0.1.3000: Flags [S], cksum 0x6d57 (correct), seq 747257338, win 65535, options [mss 1460,nop,wscale 6,nop,nop,TS val 3840999618 ecr 0,sackOK,eol], length 0
08:51:04.182534 br-lan In IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 64)
08:51:04.182738 br-lan Out IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 40)
192.168.0.1.3000 > 192.168.0.199.60315: Flags [R.], cksum 0xcbde (correct), seq 0, ack 747257339, win 0, length 0
08:51:04.182750 lan1 Out IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 40)
192.168.0.1.3000 > 192.168.0.199.60315: Flags [R.], cksum 0xcbde (correct), seq 0, ack 1, win 0, length 0
08:51:04.182757 eth0 Out IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 40)
08:51:04.210102 lan1 In IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 64)
192.168.0.199.60316 > 192.168.0.1.3000: Flags [S], cksum 0xc8eb (correct), seq 3642029610, win 65535, options [mss 1460,nop,wscale 6,nop,nop,TS val 140975356 ecr 0,sackOK,eol], length 0
08:51:04.210102 br-lan In IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 64)
08:51:04.210269 br-lan Out IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 40)
Use ps to get the process id, then lsof -n -P -p this-process-id.
Thank you for the ps tip ![]()
I cannot see any adguard process; or does it have a separate name ?
Teltonika RUTC series 2025
Device: RUTC50
Kernel: 5.15.178
Firmware: RUTC_R_00.07.14
Build: 26ed73328ac
Build date: 2025-04-18 11:57:28
root@RUTC50:~# ps
PID USER VSZ STAT COMMAND
1 root 1896 S /sbin/procd
2 root 0 SW [kthreadd]
3 root 0 IW< [rcu_gp]
4 root 0 IW< [rcu_par_gp]
5 root 0 IW< [slub_flushwq]
6 root 0 IW< [netns]
8 root 0 IW< [kworker/0:0H-kb]
10 root 0 IW< [mm_percpu_wq]
11 root 0 SW [rcu_tasks_trace]
12 root 0 SW [ksoftirqd/0]
13 root 0 IW [rcu_sched]
14 root 0 SW [migration/0]
15 root 0 SW [cpuhp/0]
16 root 0 SW [cpuhp/1]
17 root 0 SW [migration/1]
18 root 0 SW [ksoftirqd/1]
20 root 0 IW< [kworker/1:0H-ev]
21 root 0 IW< [inet_frag_wq]
23 root 0 SW [oom_reaper]
24 root 0 IW< [writeback]
25 root 0 SW [kcompactd0]
36 root 0 IW< [pencrypt_serial]
37 root 0 IW< [pdecrypt_serial]
38 root 0 IW< [cryptd]
68 root 0 IW< [kblockd]
69 root 0 IW< [blkcg_punt_bio]
70 root 0 IW< [tpm_dev_wq]
71 root 0 IW< [ata_sff]
72 root 0 SW [watchdogd]
105 root 0 SW [kswapd0]
112 root 0 IW< [kworker/1:1H-kb]
114 root 0 IW< [kthrotld]
220 root 0 SW [spi0]
274 root 0 SW [spi1]
293 root 0 SW [spi2]
393 root 0 SW [napi/mtk_eth-3]
394 root 0 SW [napi/mtk_eth-4]
420 root 0 IW< [mld]
422 root 0 IW< [ipv6_addrconf]
424 root 0 IW< [dsa_ordered]
468 root 0 SW [ubi_bgt0d]
473 root 0 IW< [kworker/0:1H-kb]
482 root 0 SW [irq/30-gpio_key]
586 root 0 SW [ubifs_bgt0_2]
728 root 0 SWN [jffs2_gcd_mtd7]
951 ubus 1616 S /sbin/ubusd
952 root 848 S /sbin/askfirst /usr/libexec/login.sh
987 root 1000 S /sbin/urngd
1370 root 0 SW [irq/19-10320000]
1371 root 0 IW< [wq_ring0]
1372 root 0 SW [irq/20-10320000]
1374 root 0 IW< [wq_ring1]
1377 root 0 SW [irq/21-10320000]
1378 root 0 IW< [wq_ring2]
1379 root 0 SW [irq/22-10320000]
1380 root 0 IW< [wq_ring3]
1680 root 0 IW< [cfg80211]
1934 root 0 SW [napi/phy0-5]
1935 root 0 SW [napi/phy0-6]
1936 root 0 SW [napi/phy0-7]
1937 root 0 SW [napi/phy0-8]
1940 root 0 SW [napi/phy0-9]
1941 root 0 SW [napi/phy0-10]
2027 root 0 SW [mt76-tx phy0]
2598 logd 2672 S /sbin/logd -S 128
2599 root 2784 S /sbin/logread -f -i -p /var/run/logread.1.pid -S 200
3582 nlbwmon 2808 SN /usr/sbin/nlbwmon -o /usr/local/share/nlbwmon/data.d
4402 dnsmasq 1532 S /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf.cfg01411c
4408 dnsmasq 1444 S /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf.cfg01411c
4453 root 9464 S /usr/sbin/hostapd -s -g /var/run/hostapd/global -f /
4454 root 9548 S /usr/sbin/wpa_supplicant -n -s -g /var/run/wpa_suppl
4508 root 4956 S /sbin/rpcd -s /var/run/ubus/ubus.sock -t 300
4565 gsm 2192 S /usr/sbin/gsmd -c
4622 root 1784 S /usr/sbin/modem_trackd
4691 gsm 9592 S /usr/sbin/mobifd
4822 root 10536 S /usr/sbin/uhttpd -f -b -h /www -x /cgi-bin -l /api -
4882 root 2156 S /usr/sbin/urcd
4949 root 1360 S /usr/sbin/dropbear -F -P /var/run/dropbear.1.pid -p
5034 root 2216 S {event_server} /usr/bin/lua /sbin/event_server
5145 root 3456 S /usr/bin/ip_blockd
5486 port_eve 1772 S /usr/bin/port_eventsd --suppress-topology
6038 root 2016 S /usr/sbin/crond -f -c /etc/crontabs -l 5
6199 root 0 IW [kworker/1:1-pm]
6399 root 1828 S /usr/bin/iomand -S
6420 root 0 SW [irq/36-ioman]
6454 root 2012 S udhcpc -p /var/run/udhcpc-wlan1-3.pid -s /lib/netifd
7085 root 3872 S /usr/bin/mdcollectd -i 10 --ignore lo
7239 root 2088 S< /usr/bin/ledman -d
7520 connchec 1228 S /usr/local/usr/sbin/connchecker -t 60 -4 1.1.1.1 -6
20129 root 9548 S /usr/sbin/gpsd
20424 root 2000 S /sbin/netifd
21323 root 0 IW [kworker/1:2-eve]
22767 root 0 SW [napi/wwan%d-12]
23024 root 2012 S udhcpc -p /var/run/udhcpc-wlan1-3.pid -s /lib/netifd
26366 root 0 IW [kworker/u4:6-nf]
26911 root 0 IW [kworker/u4:1-nf]
27742 root 0 IW [kworker/u4:2-ev]
28075 root 0 IW [kworker/u4:0-ev]
28121 root 0 IW [kworker/0:0-eve]
28256 root 2012 S udhcpc -p /var/run/udhcpc-qmimux0.pid -s /lib/netifd
28280 root 2356 S /bin/sh /usr/bin/qmuxtrack /dev/cdc-wdm0 2-1.1 17 18
28864 root 0 IW [kworker/u4:5-ev]
28985 root 0 IW [kworker/u4:7-nf]
29031 root 0 IW [kworker/0:2-pm]
29274 root 0 IW [kworker/u4:3-ev]
29355 ntpclien 1780 S /usr/sbin/ntpclient -s -l
29441 root 0 IW [kworker/0:1-pm]
29629 root 2012 S sleep 20
29630 root 1380 R /usr/sbin/dropbear -F -P /var/run/dropbear.1.pid -p
29632 root 2032 S -ash
29643 root 0 IW [kworker/1:0-pm]
29656 root 2020 R ps
root@RUTC50:~# service adguardhome status
running
AdGuardHome doesn’t appear to be running. Try to restart it and check with logread where it fails.
Adguard seems to be running
running
I restarted it with service adguardhome reload
logread does not show anything related to adguard at all even after reload
so the service is running but I got nothing in the logs
digging deeper from references in /etc/init.d/adguardhome
PROG=/usr/bin/AdGuardHome => file does not exist
/opt/var/adguardhome => does not exist
I got a folder in /var/adguardhome but nothing in it
Do you understand what is going on ?
Hmm. Which firmware version do you have ? If it is 7.14 then the root filesystem is read-only and the opkg install cannot succeed.
Could you reflash an older version (7.13.x ?) and retry ?
Ah yes it is a 7.14 version I should have read the motd.
Well.. that’s a bummer… so there is no solution to this i guess except downgrading and never updating again
maybe would docker work ? Why would teltonika do this; that is a finger to the tinkerers right ?
Forget about docker. The change in 7.14 is rather radical I haven’t installed it yet I have a lot of modified base executables / scripts I am reluctant to convert all at once. For the moment my best choice is to rebuild a fully functional (for me) firmware using the SDK but without the read-only feature. I’ll do that next week if you are interested I’ll give you the relevant instructions.
Sounds good. But then you would have to begin maintaining a fork or are you planning not updating again?
At the moment i have installed adguard on a pi i have but i also use netbird so i might be interested if that enables it for me.
Whats the story with docker ? Any limitation since 7.14 ?
Sorry im completely new to teltonika devices.
@staff any comment on the 7.14 situation please ? Are you planning on implementing adguard in the package manager ? That situation is a real bummer. I chose this router because i saw prior buying adguard and custom packages could be installed.
I’ll maintain a fork until I’ll have a clean series of patches to apply to the new ro filesystem. Should be doable just not miss anything in the VPNs section.
Using docker might be a solution however I won’t bet on it the risk is hitting the same write permissions limits.
The original post about this ro implementation is here.
Hello @RollingStone,
Could you please confirm whether your issue has been resolved or if you still require any assistance?
I recently installed AdGuard on a RUTX10 and, while browsing the forum, I came across this topic. I wanted to point out some steps to those who may be interested.
Download and install the package with each line per time:
opkg update opkg -e /etc/opkg/openwrt/distfeeds.conf update opkg -e /etc/opkg/openwrt/distfeeds.conf install adguardhome -
If the above doesn’t work, try with wget and install with opkg:
wget -P /usr/local/home/user https://downloads.openwrt.org/releases/21.02.0/packages/mi_24kc/packages/adguardhome_0.107.21-1_mipsel_24kc.ipk -
After downloading the file with wget, you should install it with the following command line:
opkg install /usr/local/home/user/adguardhome_0.107.21-1_mipsel_24kc.ipk -V2 -
After installation, edit the config file:
vi /etc/init.d/adguardhome
Substitute text after “PROG=” for
“PROG=/usr/local/usr/bin/AdGuardHome”
Also, add both lines indicated on topic Ad Blocking after Update to RUTX_R_00.07.06 - Networking Solutions - Teltonika Community
The file should look like this:
USE_PROCD=1
START=25
STOP=89
start_service() {
procd_open_instance
- Save the file by pressing “ESC” and then hitting “wq! + Enter” to save & quit
- You can check if the file is well edited with the following command line:
cat /etc/init.d/adguardhome - Reload the service with the following command line:
/etc/init.d/adguardhome reload
Then look if the service is running with the following command line:
The result should “running” - You can also check if the service is running with
ps | grep adguard - After this procedure, you should be able to go into AdGuard first configuration steps in port 3000, if you’re using 192.168.1.1 for your router then the address should 192.168.1.1:3000
IMPORTANT: Configure AdGuardHome access to a port other than 443 and 80, which are used by RUTOS itself for RUTX10 configuration. If you wish, you can keep it on port 3000.
Follow the program configuration instructions directly from the AdGuard Home configuration page: [OpenWrt Wiki] AdGuard Home
IMPORTANT: Don’t forget to make the configuration listed in the “Setup” item, described the OpenWRT page ([OpenWrt Wiki] AdGuard Home), to redirect DNS requests to AdGuardHome. In the initial configuration step, AdGuardHome itself warns that there is already a service running on port 53 (default DNS port).
If you’re having any issue installing anything after version 7.14, try to change “PROG=” in init.d files to a writeable folder, this also works with Zabbix Agent and other packages.
I hope this helps anyone searching for answers ![]()
Best regards.
