What needs to be set in the rutx50 so that GPS data is forwarded to the USB to Serial RS232 Adapter?
Quite a few options and purpose, what specific GPS data do you want to send? Have you checked the following? RUTX50 GPS - Teltonika Networks Wiki
Serial configuration for an attached USB-Serial adapter (usb_serial_xxxxxxxx) is fairly straight forward Services>Serial Utilities but then I don’t see anything under Services>GPS>NMEA Forwarding where the options are there to forward to most outputs (Lan/Network) except straight serial?
Not something I have used with the RUTX50 and thought maybe the RUT956 would be different as it has a dedicated standard serial port, but no, appears the same deal as the RUTx50?
Both RUTX50 & RUT956 support RTCM (NTRIP) out via a standard serial type port but have no idea how to forward NMEA via serial.
Going to ask the question if I am missing something with this?
Hi peter23416,
I believe you have a similar query to this post.
Hello Peter, Following is a basic outline which should duplicate on the RUTx50 what your previous router was doing?
First plug/attach a USB to Serial adapter
Services>Serial Utilities>Over IP
Check Device name which should list the attached USB-Serial adapter something like [usb_serial_mac-address]
Provide a user input New configuration name for instance reference
Select [Add]
Toggle Enable [ON]
Default serial values should be fine else reconfig to suit purpose
Under Configuration settings set
Mode [Server]
Protocol [TCP]
Listening port* [8500] See comment below
[Save & Apply]
Back on the Over IP configuration check the Instance settings which should now be [ON]
Services>GPS>General GPS configuration Enabled [ON] [Save & Apply] should get a green tick confirming GPS is Enabled
Services>GPS>NMEA
NMEA Forwarding
Select Enabled [ON]
Hostname [xxx.xxx.xxx.xxx] will be the IP of the router
Port [8500] appears to default to 8500 but must match Listening port * [8500] user entered as above
NMEA sentence settings under Forwarding enabled select the NMEA sentences & forwarding interval to forward/output [Save & Apply] Green tick confirms configuration has been applied
On the same page GPS>NMEA Hosts status should show the Hostname IP/Port/Protocol/Connection (should be UP) and number Forwarded sentences count increasing
You should now be able to run a serial cable from the USB-Serial adapter to whatever NMEA device connected and be receiving the selected NMEA sentences at the selected interval?
