NMEA Forwarding - RS232 Serial
Can the RUTx50 with a USB-Serial adapter or RUT956 forward NMEA output via standard RS232/serial cable?
Hi Mattk,
It should be possible upon enabling USB to Serial option and Serial Over IP settings.
Kindly refer to this links (Over IP / NMEA) as guides.
Make sure that the ports are the same, Mode Server, and Serial Type: Over IP.
Thanks Janmiguel, Works fine on both RUTx50 and RUT956
