WIth reference to previous discussion, just to underline that also with the latest firmware “07.09” the issues:
Passthrough : NOT SOLVED
LAN IP assigned at first connection and after the TBR reboot. WAN assigned if forced on lease time or Router force reconnect side. Voip Issue: NOT SOLVED
(log: remote site not responding)
Rollbacked as usual to 07.03 and all (WAN IP & VOIP) work perfectly.
Router: Fritz 6890
I would like to stay aligned with the latest firmware version but currently the evils far outweigh the potential benefits.
The development department is currently aware of this situation. I will inform you as soon as I receive a response from them. Thank you for your understanding and patience.
Thanks for the update.
I will wait with patience. Can u notify me when a new firmware include this fix in order to avoid to upgrade it when a new firmware is released but without this fix?
Generally speaking you have right, but in the 07.09 in the changelog i have red: " * Mobile: fixed Bridge/Passthrough modes for routed networks" but in reality issue is not solved…
Add a ‘me to’
I have just sent 6 hours trying to figure out why getting LAN IP in Bridge mode.
My first Teltonika modem, so thought I was doing something wrong.
Got around the issue by manually assigning the IP on my 3rd party firewall, but I shouldn’t have to!
You can also work around it by setting a short leasetime, e.g. 3 minutes, in the DHCP service.
There are 2 places: the DHCP service under services, and also under the “passthrough” setting.
Also note that in passthrough mode you cannot achieve the full speed…
