I am trying to connect a PFsense to the OpenVPN hub without succes. When i use the configuration file in a dedicated client on my own pc it works just fine. I followed the instructions online how to setup the connection to the PFsense. With OPNsense it also works just fine.
The problem is similar to the following thread exept the reaction under it.
Are there any tips and tricks for this issue or is it simply not compatible?
