Some days ago, I opened the Signal LEDs on RUT241, but with certains carrier, in my case Vodafone es, when netifd setup, applies --pdp-type=ip, that seems unsupported in newer versions(For making it work I downgraded to 07.04.5, that works fine).This is the fragment of log that I think that are the problem(Version 07.07):
Wed May 1 21:08:56 2024 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wda-set-data-format --link-layer-protocol raw-ip --ul-protocol qmap --dl-protocol qmap --dl-max-datagrams 16 --dl-datagram-max-size 4096 --ul-max-datagrams 11 --ul-datagram-max-size 4096 --dl-min-padding 0
Wed May 1 21:08:56 2024 daemon.notice netifd: mob1s1a1 (4737): Starting network mob1s1a1 using APN: airtelwap.es
Wed May 1 21:08:57 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,17 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profile1 --roaming-disallowed-flag no --auth-type none --apn airtelwap.es --pdp-type ip
Wed May 1 21:08:57 2024 daemon.notice netifd: mob1s1a1 (4737): “Invalid value (valid: ppp, ipv4, ipv6, ipv4v6)”
In a previous version(07.04.05), I didn´t have such errors and the 4G connection works with the same SIM card and location.
As the log indicates, it only can be these values, not ip.I changed the pdp type on /etc/config/network, but it seems to be in another script that executes before these applies.Anyone can say me where I can find these script for removing the --pdp-type ip or at least change it to ipv4 for see if it helps to solve my connectivity issues?It´s a RUT241 with MeiG modem.
I like Teltonika and it´s openness and open source love, but I don´t like to solve the problems downgrading to 2023 firmware, because the security fixes and improvements.If I can help for solving the problem,sure, I will do it!
Regards
Rafa
