Configuration of Pihole on Rut950
Hello
How can I use Pi hole with the Rut950? I already have a Pi and Pihole is already installed.
Thx
The firmware of your RUT950 is ancient.
You want to upgrade to lastest version first:
RUT950 Firmware Downloads - Teltonika Networks Wiki
Make sure to not tick “Keep Settings”.
But you will need to re-configure your box.
Hello
After the update I now have no access.
Reset again with the reset button method described here:
RUT950 Device Recovery Options - Teltonika Networks Wiki
Press and hold the button for 15 seconds.
It still remains same😬
Thx
The easiest way would be to connect a LAN cable PC ↔ RUT950 (NOT to WAN port but any of the 3 LAN ports).
Set PC to obtain IP address automatically.
Turn off wireless on your PC if applicable.
If you connect everything properly, your RUT950 will assign an 192.168.1.xxx address to your PC and you can easily access 192.168.1.1
Hello
Thank you very much for your help. I have a suspicion that the device is not updating as I keep getting the error message.
I understand and you’re right - you have a legacy device and version 06.09.5 is the latest for you :+1:
Regarding your Pihole - did you see this post and guidance how to configure this?
DNS settings for PiHole
Ive seen that post before asking here.
in lan there is no option to edit the dns
Danke für die Hilfe
And did you try DHCP-Option 6 [Pihole IP] as described in this article?
Asking as this field in your screenshots is always empty…
I have already done that. Unfortunately, the option to add the IP address of the Pi next to the number 6 is missing. I think that’s why it doesn’t work
Can you delete your browser cache
or
open 192.168.2.1 in a new private session
How to open a private browser session: Edge (Ctrl + Shift + N) | SDC Online Learning
or
try a different browser
Unfortunately, it remains the same even with the new browser
Try to enter 6,192.168.11.11
Unfortunately it does not work. The DNS must be added manually in the settings of the PC. With the Iphone, however, it does not seem to work to insert the IP address from the Pi.
