The VPN works LAN - LAN. Can add route, scan devices, only picks up dhcp enabled devices. When i add them, I can ping remotely. I have a device configured with static IP, I add it manually, but cannot ping that device (restarted hubs). The when i configure the same device with dhcp and scan device, it can pick it up and I can ping it. I need a solution to keep it on static IP
Using RUT955 routers both sides
Both LAN & WAN enabled under VPN>Routes> “clients”
I have a similar problem
I found that when i had only mobile configured it did not work. but when I plugged in the building ether into the wan port it worked.
I did have failover turned on all interfaces.
