I am trying to configure my Teltonika RUT955, setting up OpenVPN as a server,
When trying to configure the Virtual network IP address to be 10.20.0.0/24 but it seems that no matter what Network IP address or subnet I try, I see the save error. tried any kind of IP address, nothing worked out.
The device is updated (both firmware and internal modem)
I’ve tested this on one of my devices and was not able to replicate your issue. This could be related to migrating from an older firmware to a newer one whilst keeping the settings, causing issues like these in the process.
And afterwards, factory reset the device by holding down the reset button for ~12-13 seconds and then releasing. Attempt to reconfigure your OpenVPN config afterward.
