griffo
March 21, 2026, 3:14am
1
I have a RUTX50 using the latest available firmware (7.21.2).
I have existing DHCP Reservations on my RUTX50…some of these devices are connected to the network at the present time, some are not.
I have connected a new device via WiFi, and it has successfully been allocated an IPv4 address from the DHCP pool.
I want to a Static Address for this new device so using Network > DHCP > Static Leases have selected the new device, then the desired IP address.
When I click ‘Save & Apply’ an “An unexpected error occurred” message is displayed and the new Static Lease doesn’t save.
This seems to be a bug…is anyone else experiencing the same issue with this firmware version ?
Thanks in advance.
Vilius
March 25, 2026, 3:08pm
3
Hi, @griffo ,
Thank you for reporting this issue. To help us investigate further, could you please clarify a few things:
How many static leases do you currently have configured? Is it possible you’ve hit a limit?
Does the error occur when adding a lease manually (by typing the MAC address) rather than selecting from the dropdown?
Have you tried a different browser or cleared your cache before attempting to save?
Did a reboot resolve or change the behavior at all?
Could you share any relevant entries from System Logs (Status > System Logs) captured right after the error appears?
Was this working on a previous firmware version?
Your answers will help us determine whether this is a firmware bug or a configuration issue.
Looking forward to your response.
Vilius:
Hello Vilius,
I have the same issue, to answer your questions: I have RUTX50 RUTX_R_00.07.21.3
How many static leases do you currently have configured? Is it possible you’ve hit a limit? 0
Does the error occur when adding a lease manually (by typing the MAC address) rather than selecting from the dropdown? Yes
Have you tried a different browser or cleared your cache before attempting to save? Yes
Did a reboot resolve or change the behavior at all? No
880 2026-04-02 12:12:56 DHCP Network Info Leased 192.168.123.97 IP address for client 3e:64:7c:de:22:b1 - b2-nuc in LAN
Was this working on a previous firmware version? Yes
Vilius
April 2, 2026, 11:47am
5
Greetings, @osevera ,
I hope you’re doing well,
Could you please create a separate topic for your issue? This will help us avoid any confusion and ensure that we can provide you with a solution tailored specifically to your case.
Hello Vilius,
I did create a new topic althou the symptoms are the same. See
I have a RUTX50 using the latest available firmware (RUTX50 RUTX_R_00.07.21.3).
I have connected a new device via Ethernet, and it has successfully been allocated an IPv4 address from the DHCP pool.
This seems to be a bug…i…
Dear @griffo , my thread for a temporary fix.
