Antenna for RutX12
Hello there,
Iam not telecommunication or network guy so I need advice what kind of external antenna should I use for RutX12? About what parameters or inputs I should take care when buying external antenna?
Regards!
Hi…
Maybe this help you…
Please check the wiki page that Marcelo provided. Additionally, there are posts on the forum about RUTX12 antennas, such as this one:
RUTX12 - External antennas to improve wifi AP range? - #4 by JuliusL.
Kindly review the community posts, and if you still need assistance, please provide more details, and I will do my best to help you.
Hi.
Just writing about LTE (4 x SMA) and WiFi (2 x SMA)
Each LTE need two (MALE) sma to work, because RUTX12 have two LTE, you will need to use all, four at total, LTE connectores.
The RUTX12 need two (FEMALE) sma to work. This device have 2.4GHz and 5GHz, so… you need to use the two connectores to provide WiFi.
Look at the back of the device…
At the top…
The two sma at left will be used for the SIM 2 and the two sma at right will be used for the SIM 1.
The device have, for LTE usage have four female-sma, at the total, because this you need a male-sma to connect.
at the botton…
At left you can see the two sma for the WiFi. They are male-sma. Will need two female-sma to connect there.
What kind of antenna?
(google it)
Key points to consider when choosing a 4G LTE antenna:
  • Directional vs. Omni-directional:
    • Directional: Offers stronger signal by focusing the reception towards a specific tower, ideal for situations with clear line-of-sight.
    • Omni-directional: Receives signals from all directions, suitable for areas with inconsistent tower location or where you need wider coverage
okay??
Thanks Marcelo!
