Alerts for Down Lan ports
Hi, I’m trying to configure a network of RUT50 routers to notify me when any LAN ports go down using the Alerts and Automation feature in RMS.
The issue I’m running into is that the parameters I’ve configured in my monitoring templates don’t appear to be available within Alerts and Automation.
Are there any built-in parameters (dynamic, static, or otherwise) that I can use to trigger an alert when a LAN device or LAN port goes down?
We have noticed that the same topic has already been created here: Down Lan ports alerts
Your issue will be reviewed shortly, and we will continue the discussion in the original topic. This topic will be closed.
