3 OPENVPN tunnels
Dears,
How many openvpn tunnels (client, static key) can work simultaneously on teltonika RUT955?
RUT955 supports multiple client connections in OpenVPN, with a limit of 20 client instances and a single server configuration. It’s important to consider hardware and bandwidth limitations, as exceeding these limits can degrade performance.
Also, you can check a similar topic discussed before here: How to many VPN can be created from RUT950.
