It does seem to connect to the network, but i can’t ping it from an other device in the network. Can I conclude that zerotier isn’t working at all then? So it is not just the cli which is not working ?
ZeroTier still works just as expected, it’s just that particular command that doesn’t seem to give any information, we’ve tested this a few times and can confirm.
If something doesn’t work from your end, it could require you to double-check the configuration, and after any changes, make sure to re-connect to the VPN via the ZeroTier application.
The fix for this issue is going to be released (or at least is planned to be released) with the firmware version 7.19 as the R&D said. I am able to send you guys a test firmware version privately for you to install & test out if you wish, kindly let me know. If this isn’t something that is neccessary for you to have at this given moment, I’d recommend waiting for the firmware to be released officially, of course, there’s no ETA as of now, but since we’re already on 7.18.1 it shouldn’t be too long of a wait.
Thanks for the offer. But since I knew zerotier itself was still working I was able to find the problem without the CLI. So I will wait for the official update as well.
I started with a RUT200 with factory reset. I only installed the Zerotier package, and when I add an instance in Zerotier, I get missing parameters in the configuration as shown in my previous screenshot.
Will try again and report. Maybe the problem is only with fresh install.
I’ve sent both of you a form to fill out (you’ll receive it in your email inbox). The reason for that is because I’ll need both of your troubleshoot files from your devices during different scenarios so I could forward these to the R&D.
@MarkR please use the “Ticket ID” 15945-5 @jalonsom please use the “Ticket ID” 15945-6
