ZeroTier Bridging
I want to connect two LANs via ZeroTier.
I did setup according to following manuals.
  1. https://www.youtube.com/watch?v=aVwwjQNpJh4
  2. ZeroTier Configuration - Teltonika Networks Wiki
    But it doesnt work.
    Please help.
Hi Yaroslav,
May I know if you want to connect to different subnets via Zerotier? You have to add both subnets in the managed routes in zerotier. Then, Bridge to option should be none.
Let me know if this helps.
Hi Janmiguel,
I want to organise one network
Router 1
192.168.7.1
255.255.255.0
DHCP ON
Router 2
192.168.7.6
255.255.255.0
DHCP OFF
ZeroTier
192.168.7.0/24
Autoassign IP - OFF
Allow Ethernet Bridging - ON
There are few things to consider.
  • Make sure to authorize both devices in zerotier network.
  • Remove the managed IP and auto assigned managed route.
  • Instead, put the LAN subnet in managed route.
