I have seen many topic about configure WireGuard, but it is crazy how simple should be, but there is no really good info how to setup to connect to Teltonika to a WireGuard server.
wg0.conf (on ubuntu server)
[Interface]
Address = 10.0.0.1/24
ListenPort = 51820
PrivateKey = <server_privatekey>
PostUp = iptables -A FORWARD -i %i -j ACCEPT; iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
PostDown = iptables -D FORWARD -i %i -j ACCEPT; iptables -t nat -D POSTROUTING -o eth0 -j MASQUERADE
# User1 connected with normal wireGuard Client from macbook
[Peer]
PublicKey = <user_public_key>
AllowedIPs = 10.0.0.3/32
# Site1
[Peer]
PublicKey = <teltonika_public_key>
AllowedIPs = 10.0.0.2/32, 10.254.39.0/24 # teltonika lan ip is 10.254.39.1
This is the config for the user for the wireGuard client which connects to the wireguard server:
However I am not sure from how to reach the devices from client/and from server.
If I ping from server, I can not reach nor the teltonika router nor I can not ping the device connected to the router.
The cause might be a restrictive firewall.
Go to Network->Firewall->general settings, set wireguard->lan to Accept / Accept / Accept and retest.
And limit the MTU to 1280 bytes at both ends else https will probably fail.
