Wireguard not (really) restarting after power-down on RUT951 POE+
On the RUT951 POE+ I configured Wireguard as a client to connect to the Wireguard server at the office. Everything works fine and the WIreguard service is up … until there’s a power failure on the side of the RUT951. IWhen the power is restored, it powers back up and it says/seems the WIreguard is up and running. But there is no connection with the server although in the settings it says the Wireguard is up. (Even if I wait for about 20 minutes or more; Wtachdog interval at 5).
When I then shut down the Wireguard service and save it then restart the service and save again, after about a minute the Wireguard connection is back up and there’s again a link with the server.
The firmware is at 07.19.4 (the latest stable FW).
I have set the Watchdog interval to “5”.
The Persistant keep alive is at “20”.
How can I make sure the Wireguard service is really up and running after a power failure when the power comes back up and the RUT951 has restarted? Is this possibly a bug in the system?
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 17746.
