WireGuard Config RUTC50 - FritzBox
I’ve come across several WireGuard configs for connecting a RUTC50 to a FritzBox, but none of them worked reliably — most were either broken or outdated.
Has anyone got a working setup they’d be willing to share? A step-by-step guide or a current config snippet would be hugely appreciated.
Thanks in advance!
Christian
We don’t currently have a specific configuration example for setting up WireGuard with a FritzBox. However, the process on the RUTC50 side should not differ. Have you looked at this configuration example? WireGuard Configuration Example - Teltonika Networks Wiki
Could you also clarify which device is acting as the server (the one with the public IP)?
Please have a look at this topic as well as it walks through the full WireGuard configuration between a Teltonika router and a FritzBox:
If you’re still unable to get it working, please share screenshots of your configuration (excluding any sensitive information).
Check out this video : https://www.youtube.com/watch?v=-Rh9UcoKzj0
Christian
