WiFi radio configuration settings
Is it possible to add a feature to disable certain channels that can be used? I can’t seem to find anything that would show it is already possible?
For example on 2.4GHz you only want to select 1-6-11 or depending on the situation, might need to disable channels because of interference.
On 5GHz I want to be able to disable UNII3 and weather radar channels.
Tom
If you want the system to automatically select only between specific channels (e.g., 1, 6, and 11), this can be done through the CLI using UCI commands, as described in a similar topic here:
For example, to allow only channels 1, 6, and 11 on the 2.4 GHz radio, you can use:
uci set wireless.radio0.channels='1,6,11'
uci commit wireless
/etc/init.d/network restart
You can apply the same approach for your 5 GHz radio by listing only the desired channels or range to be available.
Hi Martynas,
I should add I am running 7.17.5 (the stable base firmware).
Is this something that will become available in the firmware or will it remain in CLI? How will the changes handle a firmware upgrade? Will they be overwritten?
Tom
At the moment, this functionality will remain available only via CLI. If you perform a firmware upgrade with “Keep settings” enabled, your configured radio channel settings won’t be overwritten.
