WIFI connects but does not get IP address ctd
Hello Martynas,
this is the follow up to this topic:
The problem happened again. WIFI is connected but does not get an IP address.
Here is the log file you requested. After rebooting the RUTX11 WIFI1 was connected again:
I cannot post the content of the system log file because I get this message when I try:
Dietmar
It looks like you’re connecting to a Marina Hotspot with many users - saying this as they’re using a /23 subnet mask for their DHCP pool.
Could it be that the problem is on their side and and that moment you simply get no IP as there’s no free IP address for you and their DHCP pool is maxed out?
You can check what the default lease time is for their DHCP leases and eventually talk to them to reduce the lease time to let’s say 1 hour (or less) - which should be perfectly fine for a public hotspot.
Sure that is possible but now is winter time and hardly anybode is there. Talking to “them” is very difficult since there is nobody around who could check this situation.
But when I reboot the RUTX11 is gets an IP address immediately.
Could it be that the DHCP client is giving up trying to get an IP address after some time?
Because this state will persist until I reboot the router.
Dietmar
Hello Dietmar,
Could you let us know which RutOS firmware version is installed on your RUTX11? If it’s outdated, please update it to the latest version, RUTX_R_00.07.11.3.
Additionally, could you please provide the logs from System → Maintenance → Events Log when the router connects to the Marina Hotspot AP but fails to obtain an IP address?
As @TeWe mentioned, it’s also possible that the issue is on the Marina Hotspot side, such as a long DHCP server IP lease time.
Kind regards and happy upcoming holidays!
The firmware is 7.10. I am a bit hesitant to start a firmware update from remote. The site is 600km away.
The Internet connection went down on 12/19 at around 16:00. Here is the events log around this time frame.
3457 2024-12-20 02:37:57 Mobile Data Info Mobile data disconnected (internal modem)
3456 2024-12-20 02:37:55 Failover Info WAN (mob1s2a1) is down, no more backups to switch
3455 2024-12-20 02:37:16 Failover Info WAN (mob1s2a1) is down, no more backups to switch
3454 2024-12-20 02:37:04 Failover Info WAN (mob1s2a1) is down, no more backups to switch
3453 2024-12-20 02:37:03 Network Operator Info Connected to HT HR HT HR operator (internal modem)
3452 2024-12-20 02:37:03 Network Type Info Joined LTE network (internal modem)
3451 2024-12-20 02:37:03 Mobile Data Info Mobile data connected (internal modem)
3450 2024-12-20 02:37:00 Failover Info Switched to backup WAN (mob1s2a1)
3449 2024-12-20 02:36:53 Failover Info Switched to backup WAN (mob1s2a1)
3448 2024-12-20 02:36:42 Mobile Data Info Mobile data disconnected (internal modem)
3447 2024-12-20 02:36:41 Failover Info WAN (mob1s2a1) is down, no more backups to switch
3446 2024-12-20 02:36:03 Failover Info WAN (mob1s2a1) is down, no more backups to switch
3445 2024-12-20 02:35:50 Failover Info WAN (mob1s2a1) is down, no more backups to switch
3444 2024-12-20 02:35:48 Network Operator Info Connected to HT HR HT HR operator (internal modem)
3443 2024-12-18 11:51:53 Fota Notice Firmware update to RUTX_R_00.07.11.3 is now available
3442 2024-12-18 11:25:16 SMS Notice SMS received from: HR_Telekom (internal modem)
3441 2024-12-17 16:22:27 SMS Notice SMS received from: HR_Telekom (internal modem)
3440 2024-12-17 14:32:44 Fota Notice Firmware update to RUTX_R_00.07.11.3 is now available
3439 2024-12-17 14:32:42 Web UI Notice Password auth succeeded for admin on HTTP from 198.18.1.220
3438 2024-12-17 13:46:15 SMS Info Sent 3 PDUs to +436
3437 2024-12-17 13:46:12 SMS Notice SMS received from: HR_Telekom (internal modem)
3436 2024-12-17 13:26:17 SMS Info Sent 1 PDUs to +436
3435 2024-12-17 13:26:15 SMS Notice SMS received from: HR_Telekom (internal modem)
3434 2024-12-17 13:16:42 SMS Info Sent 1 PDUs to +436
3433 2024-12-17 13:16:41 SMS Notice SMS received from: HR_Telekom (internal modem)
3432 2024-12-17 10:41:54 Startup Notice Device startup completed
3431 2024-12-17 10:41:54 Startup Info Device startup after unexpected shutdown
3430 2024-12-17 10:41:32 WiFi Notice OCY60: WiFi client connected: 10:97:BD:E4:52:4C
3429 2024-12-17 10:41:32 WiFi Notice OCY60: WiFi client connected: 44:17:93:E3:B7:48
3428 2024-12-17 10:41:32 WiFi Notice OCY60: WiFi client connected: 44:17:93:E3:5F:0C
3427 2024-12-17 10:41:32 WiFi Notice OCY60: WiFi client connected: 10:97:BD:E4:38:64
3426 2024-12-17 10:41:05 CONFIG Notice User “admin” changed events_reporting configuration
3425 2024-12-17 10:22:21 Web UI Notice Password auth succeeded for admin on HTTP from 198.18.1.220
3424 2024-12-17 08:11:14 SMS Info Sent 1 PDUs to +43676852503222
3423 2024-12-17 08:10:13 Startup Notice Device startup completed
3422 2024-12-17 08:09:53 WiFi Notice OCY60: WiFi client connected: 44:17:93:E3:B7:48
3421 2024-12-17 08:09:53 WiFi Notice OCY60: WiFi client connected: 44:17:93:E3:5F:0C
3420 2024-12-17 08:09:52 WiFi Notice OCY60: WiFi client connected: 10:97:BD:E4:52:4C
3419 2024-12-17 08:09:52 WiFi Notice OCY60: WiFi client connected: 10:97:BD:E4:38:64
3418 2024-12-17 08:09:26 WiFi Notice OCY60: WiFi client disconnected: 44:17:93:E3:B7:48
3417 2024-12-17 08:09:26 WiFi Notice OCY60: WiFi client disconnected: 10:97:BD:E4:52:4C
3416 2024-12-17 08:09:26 WiFi Notice OCY60: WiFi client disconnected: 44:17:93:E3:5F:0C
3415 2024-12-17 08:09:26 WiFi Notice OCY60: WiFi client disconnected: 10:97:BD:E4:38:64
3414 2024-12-17 08:09:07 SIM status Info SIM state changed to not inserted (internal modem)
3413 2024-12-17 08:08:47 CONFIG Notice sms_utils configuration has been changed
3412 2024-12-17 08:08:47 SMS Notice SMS received from: +4367 (internal modem)
3411 2024-12-17 08:08:47 Reboot Info Request from SMS
3410 2024-12-15 18:02:27 Fota Notice Firmware update to RUTX_R_00.07.11.2 is now available
3409 2024-12-15 18:02:16 Startup Notice Device startup completed
Dietmar
Hi…
They use some kind of portal to provide WiFi to his guests?
Do you remember… When using a PC… How long is the lease time to renew the ip address?
No portal.
I never connected a PC without the router.
But the router is connecting fine for month and then it gets into this state. After a reboot it is connecting nicely for several month before it happens again.
Dietmar
okay…
Maybe it is not a good solution… but… help a litlle, until find a better solution.
okay?
I looked at this before but there is no condition “WIFI connected but no IP address obtained”.
Simply going for a ping would reboot the router when the boat leaves the harbor.
Why so complicated?
Let him scheduled reboot every day at 04:00 in the morning (so by time instead of lost signal) and you should be fine.
Even if - for whatever reason - he doesn’t get an IP today, he will most likely get one tomorrow morning at 04:00 worst case.
And if this is still not good enough or too long to wait, you can always reboot manually via SMS command.
RUTX11 Auto Reboot - Teltonika Networks Wiki
[go all the way down to ‘Reboot Scheduler’]
