Wifi channel query about the country code
Hello, I have test the RUX11 and found that its default wifi channel is 1-11 and I would like to use 13 channel for my 2.4G device, I see the country code is US now.
It seems that I need to change the country code to get channel 13, but I would like to understand if the default country code could be changed when I got the device. So I can directly use the correct wifi channel and dont need to set the wifi country code one by one in further stage.
coz in my understanding the country code should be the same with the country it sold…
The country code isn’t included by accident. It’s there for you to select the country where you’re currently operating. Different countries have different regulations regarding radio frequencies. To comply with the laws of your country, be sure to select the appropriate country code.
Hi Marijus,
Thanks for your update, I understand that the country code setting should be same with the country
and my problem is that the default country code is US and I am in Hongkong, and I wish the HK country code should be in default so that I am able to use the correct channel without further setting.
Or is there a way to configure it more conviently for me?
It seems like this method is the most convenient way to configure it, as the other option involves using SSH/CLI.
