Wifi (ap and client) issues / unstable Rut 240 latest firmware
The wifi of my rut240 is unstable.
I have the latest firmware 07.06.17 build date 2025-01-06
I tried
  • factory reset
  • reinstall (from file) the firmware with keep settings disabled
  • changed WiFi radio settings to channel 11 (to avoid problems with ZigBee devices as I heard ZigBee channel 11 and WiFi channel 11 is a good match).
  • changed Max distance to 7m (small flat with flats left right and under me).
What else can I try?
Also the WiFi client doesn’t work well with my android accespoint (the android changes its bssid every restart of WiFi sharing). I removed the bssid while connecting to the accespoint but somehow next time it doesn’t connect and seems it has “remembered” the bssid and cannot connect to the same WiFi accespoint unless I delete the configured one and rescan and connect again.
Basically, you must upload the new firmware to the router through its administration page and allow it to upgrade.
I have done this multiple times (trying to not keep the settings).
When I try to connect a second WiFi client it doesnt connect or I loose even all WiFi connections.
What can I do to get a working WiFi ?
