Which model cell modem works in Canada?
Hi guys
When looking through the product catalog, I don’t see an indicator of which model works in which region. Which model of cell modem will work with Canadian providers (Telus or Bell) specifically?
Our apologies for the delayed response.
To determine which device is best suited for a specific mobile network provider, we first need to compare the frequency bands supported by the provider with those supported by the device.
For TELUS, the primary frequency bands are:
5G (NR):
  • n71 (600 MHz)
  • n66 (2100 MHz)
  • n78 (3500 MHz)
4G LTE:
  • B2 (1900 MHz)
  • B4/B66 (1700/2100 MHz)
  • B5 (850 MHz)
  • B7 (2600 MHz)
Rural LTE & LTE-A:
  • B12, B13, and B17 (700 MHz)
For Bell, the primary frequency bands are:
5G (NR):
  • n71 (600 MHz)
  • n66 (1700/2100 MHz)
  • n78 (3500 MHz)
4G LTE:
  • B2 (1900 MHz)
  • B4 (AWS 1700/2100 MHz)
  • B5 (850 MHz)
  • B7 (2600 MHz)
  • B13 (700 MHz)
By comparing these frequency bands with a device’s specifications, we can determine whether it is compatible with the selected network provider.
In addition to frequency band compatibility, we also need to verify whether the device has an IC (ISED) certification, as this is required for operation in Canada. You can check which certifications are available for each device in the following Wiki article:
To verify the frequency bands supported by a specific device, please navigate to the device’s product page on the Teltonika Networks website. In the Ordering section, you will find the supported frequency bands for each hardware variant.
Based on the available information, the RUTM50 is compatible with both TELUS and Bell, as it supports the required frequency bands and has the necessary IC (ISED) certification.
Additionally, could you please let us know if you have a specific device model in mind? For example, are you looking for a TRB or RUT series device? It would also be helpful if you could describe your intended use case, as this will allow us to recommend the most suitable device for your application.
We look forward to your reply.
Povilas
Thanks for the info. Sounds like the RUTm50 is good for in-town applications, while the RUTm11 is sufficient for remote sites that won’t have 5g.
Is the m series of devices newer?
Are the x series of devices not being made anymore?
