Where do I plug in my Long Ranger donor antenna into the RUTM50? There are several ports on the back panel…any input would be appreciated!
For the RUTM50, please use the main mobile antenna port to connect your long-range donor antenna.
Note that the connectors on the device are female, so the antenna’s connector should be male.
