What is the difference between a router and a gateway?
A Router is designed to direct data packets between devices on the same or similar networks, while a gateway is purely a bridge between two separate networks, like a small network and the internet.
Both of Teltonika’s routers and gateways run on RutOS, but are suited for different needs:
  • Routers typically have more Ethernet ports and Wi-Fi capabilities, while gateways usually have only one Ethernet port, although some gateways don’t even have any Ethernet interface, like the TRB141, TRB142 and the TRB145
  • Teltonika routers can have an LTE modem or not. Those modems are typically for general-purpose mobile connectivity, while our gateways always come with a mobile modem, some of which are specifically designed for low-speed IoT connectivity, like the TRB236, TRB247 and the TRB256.
  • A router is designed to manage a network of multiple devices (such as a home or business network), while a gateway is better suited to one or a few devices.
  • Both types of devices can provide NAT translation, firewall rules and VPN connectivity for their networks.
More information on our routers, gateways, and other products can be found on our website: Teltonika Networks products A Router is designed to direct data packets between devices on the same or similar networks, while a gateway is purely a bridge between two separate networks, like a small network and the internet.
More information on our routers, gateways, and other products can be found on our website: Teltonika Networks products.
