Hello.
I still have problems with 3/4/5G dropping the connection at regular intervals.
I use this as a failover to the Ubiquiti UDM-Pro but it doesn’t seem to work as stable as I thought.
I’ve tried with two different mobile operators with the same problem with both.
The problem should, as I see it, be in the RUTX50.
Anyone heard anything about Teltonika having addressed this problem?
I have sent you a form to fill out. Once completed, I will contact you privately regarding this issue. Please use ‘12836’ as the ticket ID.
Hi.
I’m just wondering what happened? I filled out the document you sent via email but I haven’t heard anything.
You should receive an email from us today.
We appreciate your patience.
Good morning.
Just wondering if you found anything wrong?
Apologies for the delay. You will receive an email from us shortly.
I’ve been using pcEngines hardware for pfsense. The 3-nic APU board is low power runs off a 12v UPS (eaton MPS12-30) along with modem and ddwrt switch/AP.
