Well thats disappointing (eSim bootstrap profile)
I was excited to come across the anouncement that eSim capable devices like my RUT241 were to be equiped with an eSim bootstrap profile in order to download and activate an eSim profile without first connecting the router to the internet via its ethernet port or through a wifi connection.
Alas, the eSim bootstrap profile is only present on newly manufactured devices, and is removed once the first eSim profile is downloaded and activated. Bummer, thats usesless for me. If the use of eSims is to be promoted by carriers, bootstrap profiles should be available any time, surely there are ways to limit the use of the associated 10MB to only eSim downloading and activating. Bootstrap guide for eSIM - Teltonika Networks Wiki
Question: can i download and activate an eSIm profile via an already active eSim profile on my RUT241? I know i can’t via the physical simcard SIM1, but can i for instance download and activate a second eSIM profile via the active first eSIM profile?
Regarding the feedback on bootstraps - thank you, I’ve noted it down and will pass it on to our R&D so that further improvements can be made.
Regarding your question, yes, if you already have an eSIM profile available, you are able to download another one without problems.
Hello @pwhooftman,
Bootstrap profile does not have any special functionality and simply acts as an initial eSIM profile, over which you can download your eSIM profile from your ISP. After it is used to load your eSIM profile, the bootstrap profile no longer has any use (since it has a low amount of data available, and the router has additional limitations limiting traffic while it is in use)
Yes, you can download a new eSIM profile from an existing mobile connection over any eSIM profile.
For convenient eSIM profile download and activation, you could also use the RMS platform.
An article explaining how to do so can be found here: How to configure eSIM profiles in RMS? - Teltonika Networks Wiki
