Webfilter plugin stopped working after firmware update on RUT200
After the latest update the webfilter stopped working.
Thank you for reaching out!
To help us recreate and investigate the issue you are experiencing, could you please provide a screenshot of your current web filter configuration?
If a screenshot isn’t possible, please share the following details instead:
  • Which firmware version did you update from? (Please note that updating from a significantly older version can sometimes cause configuration conflicts, which may require you to reconfigure your settings.)
  • Are you using basic site blocking or the proxy-based content blocker?
  • What are your exact configuration settings?
Once we have this information, we will be able to troubleshoot the issue further.
Martyna
