VXLAN - 7.09 - Any Example howto use?
i saw since Firmware 7.09 VXLAN Support ist enabled through a New package, but how can we configure it ? Will there be an example ?
I couldn’t find any in the KB
To configure VXLAN, you’ll first need to install VXLAN package (as you have already done). VXLAN configuration itself can be found in Network → Devices configuration (might need to refresh the WebUI after installing the package).
We don’t have a configuration example for now, but once it’s ready, it will be available on our Wiki: Teltonika Networks Wiki
Just to provide a broad overview, once a VXLAN device is configured, you’ll need to create a Network interface for it. Navigate to LAN or WAN interfaces, create a new network interface, and select physical interface as vxlan1 (or the name that was chosen during VXLAN creation). Firewall rules to accept VXLAN connections should be added automatically after configuring the VXLAN device.
