Vpn to plc on static ip
Hello All,
Hopefully you can help me.
I`m trying to remote onto a PLC via a RUT241.
RUT241 Lan is 192.168.9.1
PLC is 192.168.9.200.
Subnet: 255.255.255.0
GW: 192.168.9.1
I couldn`t see the PLC at first on the RUT241 which was weird.
Adding a static route on the UI of the RUT241, did fix that and I can now see it and ping it successfully via the diagnostics on the UI of the RUT241.
I setup a VPN with my user, a device (the RUT241) and I can now scan for devices and see the PLC. (192.168.1.200)
I Run the teltonika RMS VPN tool and get the VPN running etc. But i cannot use the programming software to connect to the PLC and i can`t successfully ping the device?
What am i doing wrong?
Have you enabled LAN forwarding and added a static route to the VPN hub? You can do this by navigating to Routes and clicking the buttons shown in the image below.
A static route for the entire subnet would look like the example shown below. If you only want to route traffic to a specific IP address, use the 255.255.255.255 netmask.
For additional information about VPN hubs, please refer to the following link:
Hello Justinas,
Thanks for the info that’s all good, i think its the PC side my pc in particular.
I can ping the PLC from the router UI.
If i tracert from my PC is doesn`t go down the VPN adapter just my normal network adapter, then dies so i think that is the issue?
Cheers
On Windows, you can specify the interface from which the ping is sent by using the -S option.
The command would look like this:
ping -S 192.168.1.103 8.8.8.8
