VPN teltonika to teltonika
Hello Community,
Could you please advise?
I’ve tried several options but still haven’t found a solution.
I successfully established an IPsec VPN between a Cisco device and Teltonika 1.
Now, I need to set up a VPN tunnel between Teltonika 1 and Teltonika 2 so that the Cisco device can access the LAN on Teltonika 2.
  • Teltonika 1 has a static public IP address.
  • Teltonika 2 has only a dynamic IP address.
For my last attempt, I followed this template:
Default Route Configuration - Teltonika to Teltonika
The Teltonika routers show the connection as Active on the Hub side and Connected on the Spoke side. However, I still cannot ping the LAN on either side.
Is this the correct approach? Or is there something I’m missing?
Here’s my network setup:
Cisco LAN: 192.168.80.0/24
Teltonika 1 [RUT901]:** 192.168.100.0/24
Teltonika 2 [RUT951]:** 192.168.101.0/24
Any suggestions or insights would be greatly appreciated.
Thank you!
Apologies for a delayed response.
Could you kindly confirm if you’re still experiencing issues with configuring the IPsec tunnel between RUT9 and Cisco devices?
If the issue persists, I would recommend checking these IPsec configuration examples, which may provide further insights and help troubleshoot what might be going wrong. They could shed some light on any configuration details that might be missed:
Setting up an IPsec tunnel between Teltonika Networks and Cisco devices
IPsec RUTOS configuration example
Please let me know if the issue still persists and provide IPsec logs from the hub/spoke sides, and feel free to reach out if you need any further assistance.
