VPN "keeps going down" cant access IP adresse
Hi. Im having a VPN Hub running between 2 sites with a rutX50, but i keep having problems that i cant access the IP adresses behind.
The VPN has a server at one end that accesses equipment on the other end (on the opther VPN side) But after some time the connection fails. When i reboot at the server/pc end it works again for some time.
I can access the server trougt the vpn, but the equipment can not.
Can there be something that stops it fom communicating to the equipment ?
Thank you for reaching out.
To begin troubleshooting this, could you please check and confirm whether:
  1. The route to the end device connected to the RUTX50 is properly added, and LAN forwarding is enabled on this client?
  2. Firewall LAN → WAN zone is modified to allow the inter-zone forwarding as described in the RMS VPN Hubs example here: RMS VPN Hubs — Modifying Firewall Zones
  3. The masquerading is enabled on the LAN zone, as it’s often necessary for proper traffic handling across VPN links.
  4. If possible, could you also provide OpenVPN logs from the RUTX50 client side when the issue occurs? You can find them in the device’s WebUI under Services → VPN → OpenVPN page.
Looking forward to your feedback.
