I understand that Bahrain is now not accessible. But it should be possible to easy relocate VPN Hubs to other location without creating completly new one. Or maybe there is such as option - if yes, where? Also, I cannot delete unused VPNs localised in Bahrain - why? I can click the delete icons or options, but the VPNs are still in the list. How to delete them?
Dear Maol,
I had the exactly same issue with you. The suggestion from Teltonika is to make the new VPN hub again from scratch. I still face the same issue where I cannot remove them completely, and the thing I did at least is to unassign every client and device from the hub, disable it, and then proceed to create the new hub.
Hope it helps,
Manos Anastasiou
Creating completly new hub from scratch is of course possible but if you have some tens of them, and every VPN has lot of different user… is not practical and takes a lot of time.
I understand, we are on the same page here.
At least there is a solution where we can rely on.
Best regards
