VPN Hub Routes - not all working
i have a question about the defined Routes because i am only able to access some of them but not all.
As Example most devices are found automatically (especially those 2 which a cannot ping), i added them as a Route from the device, but for 2 of those devices even a ping is not possible.
Does anybody have an idead?
Thank you for reaching out.
Could you confirm you’ve made the necessary firewall zone modifications as described in the example section here.
Additionally, you might try enabling Masquerading on the LAN zone (Network → Firewall → Zones) to see if that helps resolve the issue.
Let me know if this helps or if you need further assistance.
Hello Martynas,
maybe my information was a bit too less.
In the Network is only one RUT241, and on this are 2 external devices with 3 IP’s connected on WAN and LAN in bridge mode.
The IP of the device on WAN i can ping and connect, the 2 IP’s on second device on LAN port i cannot ping and connect?
The VPN settings in the Firewall are Auto like they are assigned on creating the VPN Hub and connection.
I could share some pictures if needed, just tell me.
