VPN Hub problems after update 7.11.1
Hi guys,
I have updated 19 devices and 5 of them are not connecting to the VPN Hub after the update.
The ping error is Destination Port Unreachable
I see a lot of errors about TLS Handshake and
490 Mon Dec  2 10:28:17 2024 daemon.err openvpn(rms_1VJEo1zx4m4AGSgk)[4355]: OPTIONS ERROR: server pushed compression settings that are not allowed and will result in a non-working connection. See also allow-compression in the manual.
491 Mon Dec  2 10:28:17 2024 daemon.err openvpn(rms_1VJEo1zx4m4AGSgk)[4355]: ERROR: Failed to apply push options
492 Mon Dec  2 10:28:17 2024 daemon.err openvpn(rms_1VJEo1zx4m4AGSgk)[4355]: Failed to open tun/tap interface
When I try to re-enable VPN the config files seems empty. It seems very broken to me. Even a new device on a new Hub does not work on 7.11.1.
What is wrong? How to fix this?
Version: RUT9M_R_00.07.11.1
Devices: RUT951
Maarten
I just made it work by removing the auto config from the VPN Hub, creating a new user per device in the Hub, importing that .ovpn manually and readding the route to the right user. I had to do this for all my devices of course.
Now all my devices are restored on temperory solutions!
