Hello, I have several “rut200” routers configured as clients through Open VPN and since the new 7.10 update they have stopped working, apparently the configuration is the same as the one I had, I am using a bf cbc 128 encryption and it does not let me routers connect because it tells me that it is an insecure configuration, is there any configuration to reestablish the connection at the moment with this encryption?
I apologize for any inconvenience this issue may have caused.
Could you please upgrade your device to the latest 7.10.4 firmware version and check if the issue still persists? You can download the firmware image here: RUT200 Firmware Downloads.
If the issue persists, please navigate to System → Maintenance → Troubleshoot, click Show next to System Logs, and share the logs related to your VPN connection.
Thank you.
I tested OpenVPN using the same encryption settings and observed the same logs regarding BF-CBC 128. However, the connection was established successfully.
Could you please confirm the following:
- Does the Status display “Connected” or “Disconnected”?
- What are you using as a VPN server?
- Have you checked the logs on the VPN server for any relevant errors or messages?
Additionally, please share your configurations so I can review them and ensure everything is set up correctly.
Looking forward to your response.
Good morning, I finally saw that it was a problem with the server that was not working as it should, I restarted the Open VPN services and all the routes connected correctly.
Thank you very much for the help.
Greetings.
I’m glad to hear the issue is resolved!
Please feel free to reach out if you have any more questions or need further assistance regarding this topic.
